External Detectors For Cctv
Alex
Hi,
I want to install some external PIR for the CCTV system. Unfortunately the cables come out of the wall at approx 4m height. Customer wants them to stay there so no one can easily tamper with the PIRs. I know that Redwall needs to be installed at about 2m30cm to work properly. Is there anything else I could use which would work at 4m? Maybe GJD?
Thanks for your help,
Alex
cheers,
Alex
I use GJD Elites, although on my house i had fitted Opal xls so conected the A output to a relay (4 of them) to trigger the dome/Activity
The good thing about the gjds are you dont know which way there pointing.
Watchdog Security (Manchester)
