Gardtec 370 - Need Help
Guest ysabelle
Guest ysabelle
Hello all, Great forum! Ok, the house we moved into has a Gardtec 370 (says 360 on manual). Everytime I do a full SET the system 'thinks' that the PIR numbered #3 is active even though the LED on the PIR is not lit. The system of course will not set. The PIR in question does seem to detect movement ok and I can get around this by removing that zone (PIR #3) on a partial set.
Do the symptoms above sound like a faulty PIR? Can I just swap it out with another one to test? I do not know the engineers code so am concerned about screwing up the system. Any advice is greatly appreciated!
cheers
its one or one of..... device/ cable / controls
Guest ysabelle
Thanks. I am gojng to try and disable the cable to that PIR from the alarm unit. if that fails, call an engineer or change my alarm!! cheers
