Scantronic 9448 Panel Delay Timer
Guest Nick Jupp
Guest Nick Jupp
After powering down (including disconnecting the battery) the panel to move a PIR, the delay between setting the alarm and it triggering seems to have reset to 10 seconds, which isn't enough time to leave the house without the alarm going off.
Is there a way to reprogramme this? It's not in the user guide, so guess it's a programming/intallation issue and therefore may not be able to be posted here :( ?
Thanks
Nick
Sorry, this requires an engineer to deal with.
cheers
Guest Nick Jupp
Where did you install the new pir? could it be on the entry exit route by any chance?
I just had to reroute the wire, PIR is in the same place. The delay is definately shorter than it was before...
Thanks
Nick
cheers
OK, thanks...
