Automatic Electronic Cinema Screen
Red Fox UK
why does all this gubbins need to be at the projector end, cant it be mounted with it's psu behind the screen or elsewhere in the room?
Last comment here
RS Components
Agggggggggggggggggggggggggggggg
See post number 3 on here or close to it
Timed wotever voltage momentary switching or permanently but does everything on the box and more.
last time i even look at this thread its like a bad headache.
c h e e r s
It doesnt matter which end it goes really, but the 240v sources are on the ceiling and I dont want a black brick on the ceiling.
Red Fox | Hosting
Affordable and Reliable UK Based Web Hosting
why black brick, get a white project box and mount it in that.
Last comment here
RS Components
I KNEW of the device I posted before I started this thread - the thing I was questioning is wheter it was possible without a seperate 12v supply.
Red Fox | Hosting
Its an option, just didnt know if compact devices existed.
12v switchmode like a laptop psu??
IT IS FOR @@@@@@@@`S SAKE, RING RS LIKE I SAID ON POST NUMBER 2
MADE ME A LIAR NOW, COS I REPOSTED....................
I wont say what i feel cos its not polite to swear on a public forum!!!!!!!!!!
Oh and cheers
How many times does this need to be said:
You CANNOT run a relay off of the current the projector trigger provides!!
http://www.amplicon.co.uk/dr-prod3.cfm/sub...oupId/11765.htm
after a quick look i got these but they are about 2 inches
Yer, these are the type of things that would be perfect...
Red Fox | Hosting
Right then, what does the trigger supply to trigger the relay?
Is it voltage free, is it dc, ac or what?
There is a myriad of relays that work with any voltage, or none what so ever, some as you stated may need a independent supply.
Your toy, i bet can be run with anyone of the above if dealt with correctly...............how the hell do pubs run the things..............we are, sorry i was trying to help, ring A sky installer hes probably got the item you require bouncing the part you need in the back of his van covered in tomato soup and croutons.
Last time i try to help a condescending person who wont even ring a specialist suppliers.
Have an interesting life.
cheers
