Guest Posted November 3, 2006 Posted November 3, 2006 Your posting is small, so i assumed your not a great user of this site. Now it seems your the server provider. I know a few server providers, your probably too busy to watch all the time then. However when my friends need to know something they do, with politeness and half an idea. If not they ask , or use the service providers tech line. Thats me pooped then as you can trace my ip thanks in advance for viruses and mac incompatibly issues
Red Fox UK Posted November 3, 2006 Author Posted November 3, 2006 Old, i do think your wrong regarding your relay as without additional power from somewhere it cant work. But you did tell me of some fangled led with built in voltage drop circuit already encapsulated so i am ready to stand corrected. Ditto, I want to stand corrected and see this product that doesnt need a 12v supply. The first several posts of this explain why the current on a 12v projector trigger is no good: http://www.avforums.com/forums/showthread.php?t=137442 This in particular: http://www.avforums.com/forums/showpost.ph...amp;postcount=6 Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
Guest Posted November 3, 2006 Posted November 3, 2006 Additional supplies are not needed with the correct relays................... Brick wall time again
Red Fox UK Posted November 3, 2006 Author Posted November 3, 2006 What the hell are those Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
