bellman Posted November 4, 2006 Posted November 4, 2006 If I remember correctly the procedure is the same as on the lcd models. User guide is attached. Regards Bellman Abacus_User_Guide.pdf Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
whistle Posted November 5, 2006 Posted November 5, 2006 Why not just hard wire a lcd rkp on to it temp. just to program it.
Guest Chris C Posted November 14, 2006 Posted November 14, 2006 Why not just hard wire a lcd rkp on to it temp. just to program it. Thanks for the Info. I have managed to get an LCD Controller Keypad and will try it out at the weekend.
Guest Chris C Posted November 14, 2006 Posted November 14, 2006 If I remember correctly the procedure is the same as on the lcd models.User guide is attached. Regards Bellman Sorry for the delay in getting back to you. I really do appreciate all the help that has been given to me so far. The user guide was very informative. Thanks for the Info. I have managed to get an LCD Controller Keypad and will try it out at the weekend.
Guest Chris C Posted November 14, 2006 Posted November 14, 2006 It was a question of enter code to show "SE", press No button until get into the code menu but I confess now that I'm rusty on the Abacus range and no user manual is available on the site.Very similar to the old Gardtec 800 led if I remember. Thanks for the info. I have been advised that the best way to solve my problem is to obtain an LCD Keypad. This should make the programming a whole lot more visible. I have now got an LCD unit and will attempt to programme it soon. Thanks again for your help. Chris
Guest Chris C Posted November 14, 2006 Posted November 14, 2006 You can attach an L.C.D keypad to the 6r(which makes programming a whole lot easier) but you need a lead which are becoming pretty hard to come by...i did manage to aquire one from bosch about 6 months ago Have now acquired an LCD Keypad for the Abacus 6R. I shall try to programme it at the weekend. Many thanks for all your help. Chris
