New Installation
Guest Tony 200
Guest Tony 200
Hi everyone,
I have resently fitted an alarm system having not fitted one before and have a problem in that i wired it all ok, fitting the front door to the E/E terminals and all other zones accordingly however after testing, everything works well exept that the E/E zone only sounds the internal bell. Do i need to link to another zone and programe that for E/E maybe? Help please!!!! The alarm type is a 9448 with a 9427 key pad.
Hi everyone,
Are you giving it chance to alarm properly as you may just be hearing the entry count down timer?
The older I get, the faster I was.
What do you mean exactly, you open the door and the entry exit timer starts?
Hi everyone,
If you exceed half the programmed entry time the internal sounder will emit an internal alarm tone, go to control panel and key-in your access code to stop sounder and return to Day.
In other words, (1min entry time), open door, entry sound, at 30secs, LOUDER entry/alarm sound, this one is saying TURN ME OFF or I will go into FULL ALARM condition - outside sounder as well, does this help?
magpye
ps It's called dual-ply entry time
Guest Tony 200
Yes positive its armed, the alarm sounds the same internally as any other
Guest Tony 200
magpye
Not sure to test the E/E zone i set full wait until armed opennE/E then get entry alarm until time elapsed then full internal alarm sounds but not external.
In other words,
(example > 1min entry time, )
open door,
entry sound,
at 30secs you get a
(this one is saying TURN ME OFF or I will go into FULL ALARM condition
AT 1min > outside sounder as well.
Are you waiting long enough?
If you are, I would suggest you have a problem with your outside sounder
magpye
European regs.. external siren will not sound until after 30 secs if E/E time expires.. wait a bit longer and see what happens :)
Guest Tony 200
after another 30 seconds, it should then sound outside as well
That may be the case as i only quickly checked if extrnal sounder was activated on entering the E/E zone and then punched in code thanks for that il give it a go
European regs ????? A Scantronic 9448 ??????
