Guest godfrey Posted February 8, 2004 Posted February 8, 2004 I have recently moved into a house with an alarm fitted in 1993. The control panel is Concept "Advanced Microprocessor Control". It worked fine for the first couple of months. Recently, during any power cut the internal alarm sounder sounds, (but not the external strobe) and the keypad will not respond. Once power is restored, the control panel functions OK, but the security code has returned to the default code and needs to be reprogramed. During some decorating we have unscrewed some PIR panels from wall (not disconnected). These are back in place. We have also had the power off again. However the control panel now shows Power and Tamper lights and will not respond to keypad. The Zone lights continue to light up when there is any movement in the zone. I only have the basic card with user instructions. Please can anyone provide advice or user manuals? Many thanks Quote
j.paul Posted February 8, 2004 Posted February 8, 2004 The battery is faulty in the main panel, you will need to power down the panel, (remove battery, the mains supply). Then power backup, mains first then New Battery. enter 0123. Close all tamper (replace lid on panel etc) press reset the panel should now go back to day mode, if not then will need to get someone (alarm company) to look at it. The basic card is the user manual!!! Regs jpaul Quote There are no stupid questions, but there are a LOT of inquisitive idiots.
Guest godfrey Posted February 8, 2004 Posted February 8, 2004 Many thanks. I'll give that a try. Quote
Jean Felthouse Posted October 19, 2018 Posted October 19, 2018 On 08/02/2004 at 18:27, j.paul said: The battery is faulty in the main panel, you will need to power down the panel, (remove battery, the mains supply). Then power backup, mains first then New Battery. enter 0123. Close all tamper (replace lid on panel etc) press reset the panel should now go back to day mode, if not then will need to get someone (alarm company) to look at it. The basic card is the user manual!!! Regs jpaul M On 08/02/2004 at 18:27, j.paul said: The battery is faulty in the main panel, you will need to power down the panel, (remove battery, the mains supply). Then power backup, mains first then New Battery. enter 0123. Close all tamper (replace lid on panel etc) press reset the panel should now go back to day mode, if not then will need to get someone (alarm company) to look at it. The basic card is the user manual!!! Regs jpaul Same problem here. We have put in a new battery and entered 0123 it’s now gone back to day mode. How do I set my own code in Quote
al-yeti Posted October 19, 2018 Posted October 19, 2018 3 hours ago, Jean Felthouse said: M Same problem here. We have put in a new battery and entered 0123 it’s now gone back to day mode. How do I set my own code in Get user manual? Quote
Jean Felthouse Posted October 19, 2018 Posted October 19, 2018 8 minutes ago, al-yeti said: Get user manual? Can’t find the user manual for this his alarm. Thanks anyway Quote
al-yeti Posted October 19, 2018 Posted October 19, 2018 1 hour ago, Jean Felthouse said: Can’t find the user manual for this his alarm. Thanks anyway Might be Press prog Enter existing code Press 8 Four zones light up Enter new code Press reset New code should work , this is an old user manual I have I don't know how many panels are called concept but might be same Quote
