Globel Tamper 9651 Scantronic
Guest mark emery
Guest mark emery
CAN ANY ONE HELP IVE JUST WIRED A SCANTRONIC 9651 BUT WHEN I TRY TO LEAVE INSTALLER MODE IT SAYS CHECKING SYS AND KEEPS CHECKING ZONES 1 TO 8 CONSTANTLY I CAN ONLY GO BACK TO INSTALLER MODE. PLEASE HELP :(
Check the global tamper connection.
If your using conventional wiring check your tamper circuit is closed or if you are using FSL make sure you have programmed it correctly in option 21.
