Guest Bobski Posted November 11, 2006 Posted November 11, 2006 I have come across a Fire Panel with a "Power Fault" this panel has: CODE ALT 514" on the front. Does anyone know the make of this panel or heard of it.... As i could do with a user manual ( for my customer..) Thanks.
sparky999 Posted November 11, 2006 Posted November 11, 2006 I have come across a Fire Panel with a "Power Fault" this panel has: CODE ALT 514" on the front.Does anyone know the make of this panel or heard of it.... As i could do with a user manual ( for my customer..) Thanks. It`s a Rafiki Panel 514 is the access code - Pete I`ll post the manual if I can find it P.S. found it Twinflex_User_Guide.pdf Peter Robinson Freelance M:07889038650
Guest Posted November 11, 2006 Posted November 11, 2006 It`s a Rafiki Panel 514 is the access code - Pete The Rafiki is in the same plastic case as a CB200 which came first but is not a two wire system
sparky999 Posted November 11, 2006 Posted November 11, 2006 The Rafiki is in the same plastic case as a CB200 which came first but is not a two wire system THe ones I work on are combined smoke and sounder Peter Robinson Freelance M:07889038650
ee8mjb Posted November 12, 2006 Posted November 12, 2006 Rafiki shared the plastic mould for the case with several other companies who have used it for completely unrelated panels and is flippin' confusing at times, especially now Rafiki rebadge theirs as well. If it has alt 514 on it then definitely a Rafiki twinflex as the other stuff has different software, and the manual link above is spot on. We specialise in Rafiki if you need any more help, as do several other members on here. Matt
ee8mjb Posted November 12, 2006 Posted November 12, 2006 I meant to add that Rafiki have full manuals including installation and engineer manuals on their website: www.rafikiprotection.com Matt
Guest Posted November 12, 2006 Posted November 12, 2006 If it has alt 514 on it then definitely a Rafiki twinflex as the other stuff has different software, and the manual link above is spot on. well assuming its a two wire system other wise its a CB200 both can be brand with other names.....
F C E Posted November 12, 2006 Posted November 12, 2006 well assuming its a two wire system other wise its a CB200 both can be brand with other names..... CB200 doesn't have the ALT Key only the twinflex one has All comments in this post are my own views and do not necessarily reflect the views of my employer
