Guest kinbroke Posted November 12, 2006 Posted November 12, 2006 Hi all, had to turn off the power to the panel and immediately the bell sounded. When turning back on power 5 mins later I have no LED
camerabloke Posted November 12, 2006 Posted November 12, 2006 thanks for telling us Eucam Security Systems 0845 4630 746 www.eucam.co.uk
bellman Posted November 12, 2006 Posted November 12, 2006 Hi all, had to turn off the power to the panel and immediately the bell sounded. When turning back on power 5 mins later I have no LED’s lit on keypad. Keypad still lights and sounds when button pressed however alarm not working. Battery and charging circuit are ok and all the fuses are ok as well. Thanks,kinbroke If the box sounded immediately mains was removed then that would indicate a battery fault. diss the mains again, then dis the battery, power the panel up mains only and if it works correctly then the batt is goosed. Just because it shows 12v at the battery doesn't mean it's not faulty, what tests have you done on it and the charging cct? BE WARNED MAINS CAN KILL, USE CAUTION!! Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest Posted November 12, 2006 Posted November 12, 2006 This MAINS chap sounds like a right hard geezer. But hes right, don't mess about if your unsure, and it sounds like you need a new battery.
Guest kinbroke Posted November 12, 2006 Posted November 12, 2006 Thanks people (Even the sarcastic one's) Have decided to get an expert in.
camerabloke Posted November 12, 2006 Posted November 12, 2006 Thanks people (Even the sarcastic one's) Have decided to get an expert in. glad i could help by the way, good choice Eucam Security Systems 0845 4630 746 www.eucam.co.uk
