Sg Ii Random Chirps
Guest Jason
Hi All
Have an FAI Security Guard II that came with the house. I am aware of the normal on-off noise and low battery beeps, but now I have a single chirp that goes off all the time (even if I key it off).
I have read all the manuals which talk about beeps, not a single chirp (every couple of minutes).
Does anyone know what this is? I am guessing it might be a dead/dying main battery. Does anyone know what batteries are inside these things?
Regards
Jason
  • 2 weeks later...
It is probably the battery causing it to chirp. You should have a charger for it. There is a place right on the bottom of the alarm, plug it in there, plug in the mains, then it will bleep when its fully charged. Will probably need recharging about every 6 months, depending on usage.
If you haven't got the charger then the point where you attach it to the alarm is fairly standard, you should be able to buy a universal charger that would fit it.
Rachael
Hi All
Regards
Jason
