Scantronic 9500 bits
Guest Sparks
Hi,
I have a Scantronic 9500 system in my house - I know it's old, but it does the job B)
I am after any bits people may be about to throw out etc.
I am especially interested in a remote keypad!
Any offers!
Sparks...
Hi all,
I'm over-run with 9500 bits, what bits do you want?
i've got: Pcb's, housings, transformers, k/pads, lim's, even relay boards and plug on digicoms.
as for remote keypads, what software version has it got?
as there are several different k/pads for the 9500 (all look and work the same, just software has to match the k/pad)
hope this helps
regards
Bellman
Bellman,
Sounds good stuff!!
The panel reports when entering Engineering mode
"v2.26 3-OCT-88"
The main EEPROM on the main board (Which was blown when I got the panel, but I managed to get a replacement from Scantronic many years ago!) has the following: -
44319
4-10-88
IC Type 27C512
9500 MPLX MK2
I think there is a problem with my power supply board, as on removing the battery, the alarm does not report this - from the manual, it looks as if it should)
The PSU has a sticker bearing the following
53092
8687K
Basically I am interested in anything that will upgrade the alarm (Like a newer main PCB for example)
Where abouts are you located - I am in Orpington, Kent.
Thanks!
Sparks...
Do you know if the eeprom in the panel is the same as the eeprom in a keypad?
For example, say I had a keypad with newer software programmed (I have seen one on eBay with version 4.2 (my panel is 2.26)), Could I just copy that eeprom onto the eeprom that is in the main panel?
(using an eeprom programmer of course!)
Thanks!
