Recommend A Panel?
Guest KSH
It's looking like my panel might be dead, any recommendations for a new one, must be 4 zones min, only 1 access point used to the house, let me know if you need any more details
What's your budget?
Cheap and reliable: Scantronic 9448.
Bit more upmarket with an LCD keypad: Gardtec CP8L or Texecom Veritas Excel.
Trade Member
Guest Dupi Security
Hi There
Might I recoment the Texecom Veritas R8 Plus which includes 8 zones and is very simple to install and use.
If you need any advise of help with the Texecom range please do not hesitate to contact me: william@dupi.co.uk or 07014 215043
Many Thanks, William
Hi There
Thanks, will check your suggestions out.
Budget - Don't we all want everything for nothing :-) dunno to be honest, about
Go for the Excel mate, same as the R8+ but with a proper keypad.
Guest Dupi Security
If you go for the Veritas R8 Plus with a LCD keypad you would be looking to pay around about xx however if you went for the Veritas Excel which is the same as the R8 Plus just with a LCD keypad you would be looking at around
  • 2 weeks later...
~Hello,
I have a Scantronic 9200 (very old I know)
All was working fine until some klutz decided to cut the wires on the internal buzzer and appears to lave lost a part at the sametime.
I now find I can no longer run the alarm.
Is there an easy way of bypassing the buzzer altogether so that the alarm can be armed?
I will have a new alarm installed, but not just yet. I woud like to get this one running again.
many thanks in advance
