What Cable For Network
Hi guys
I am installing an IP network to link three multiplexers together. As the units will be sharing camera pictures I want to fully utilise the gigabit network cards employed in these units.
Can you run data at gigabit over cat5e or do you need cat6?
cheers
Dave
cat5e will do gigabit, cat6 is a bit different so i only use cat5e, i doubt you will max out a 100 meg link though
Are you sure? There will be 48 cameras running over it backwards and forwards. We will also have 4 audio streams.
cheers
Dave
if your doing that then i recommend a proper managed switch to get as much out of your bandwidth. Also i dont know of any gigabit ported ip cams
Not using IP cams.
Using three Pelco multiplexers, 16 cameras on each. You can network them all together and share camera images from remote DVR's in a tree configuration. The cameras are composite, it's the DVR's that have a Gigabit ports.
cheers
Dave
oh i see its one of the dx's then
i dont know but i would have thought it only pulled images as it needs them not all the time.
I still doubt you would max out a 100 meg (thats about 10megabytes per second) and i bet your high spec pc wouldnt have an easy time shifting this amount of data
Go cat6 it is designed more towards 1gig and is readily available as cat 5e these days not a huge difference in price. As stated previously though cat5e will run at 1gig but remember to puch down all pairs as it uses all 4 (unlike 100meg which only uses 2)
Yeah DX8116 new version of DX8016. Very clever pieces of kit, but expensive :fear:
It has got a bandwith throttle! :lol:
Dave
i have looked at em, did you get the whole 'designed by a guy from dell' spiel lol
looks superb and it runs linux not ms anymore so should be stable..
I still say cat 5e but thats probably because i have never fitted cat6 .
Invest good money on your switch if you have a cheapy switch it will perform worse than a good 100meg network mate
James
