esp-protocol Posted November 16, 2006 Posted November 16, 2006 I'm looking for "BMS" system other than Trend and any equally over priced kit. Very simply it is to monitor equipment in a computer room, eg AC units, UPS, PDUs various run/fault/trip outputs etc etc. A lot of the outputs are volt free contacts, and not a real problem however, we will also be required to take other info such as current/voltage/load etc from the PDUs and various kit., most likely using a mix of CTs. and possibly trying to "talk" directly to the kit using protocol translators. We have a system that does most of it but is causing me problems. Does anyone know what I'm talking about, and suggest any control specialist who might be able to help?? Thanks Dave
Guest Sparkey Posted November 18, 2006 Posted November 18, 2006 look at satchwell or siemens. Having worked on various systems I found that trend was the most user friendly.
esp-protocol Posted November 18, 2006 Author Posted November 18, 2006 Strange, I'd always been informed that "Trend" and "user friendly" didn't go in the same sentence. I thought Trend (and most likely siemens) were pretty much closed shops. Thanks for the suggestion but I found a firm called North Building Technologies which looks good.
stewymac Posted November 21, 2006 Posted November 21, 2006 Strange, I'd always been informed that "Trend" and "user friendly" didn't go in the same sentence.I thought Trend (and most likely siemens) were pretty much closed shops. Thanks for the suggestion but I found a firm called North Building Technologies which looks good. allen martin are good....fitted loads when in that game,its more heating control i agree but at the end of the day its inputs and outputs....i take it thats what you need.... agree trend/landis/satchwell..i never liked..
