Alister Posted November 16, 2006 Share Posted November 16, 2006 I visited one of my sites today which, amongst other cameras, has two Dennard 2050 P/T/Z domes (installed approx 4 years ago), they are controlled by a Dedicated Micro's KBX3 keypad via a DM DS2 DVR - the system is generally working well although both domes are "creeping" slightly, particularly just after being manually panned - they creep a bit then stop. Any ideas? Link to comment Share on other sites More sharing options...
WatchdogSecurity Posted November 16, 2006 Share Posted November 16, 2006 replace the keyboard. You try recalibrating it but we have had to replace a few keybaords latly on maint James Yeh my thoughts also, i think you hold down * on connecting the keyboard and rotate it then twist it to calibrate. Watchdog Security (Manchester) Link to comment Share on other sites More sharing options...
Phil Sumner Posted November 16, 2006 Share Posted November 16, 2006 Do you have any other PTZs on the Sprite? If it's all your PTZs on the unit which are moving slightly then the above poster is correct, simply calibrate the joystick. Unplug the keyboard, plug it back in whilst holding down the star key. Move the joystick to it's extremes (up, down, left, right, twist to zoom in and out) then press the star key again. -- psumner@dmicros.com Manufacturer Link to comment Share on other sites More sharing options...
Guest Posted November 16, 2006 Share Posted November 16, 2006 Do you have any other PTZs on the Sprite? If it's all your PTZs on the unit which are moving slightly then the above poster is correct, simply calibrate the joystick.Unplug the keyboard, plug it back in whilst holding down the star key. Move the joystick to it's extremes (up, down, left, right, twist to zoom in and out) then press the star key again. I have known domes to creep if they are using coaxial telemetry and the cables are subject to noise. The joystick calibration sounds favourite and would be a perfect place to start. Dave Link to comment Share on other sites More sharing options...
Guest walter Posted November 17, 2006 Share Posted November 17, 2006 i have had this and its usually the keyboard mate, if you unplug it i bet it stops RS485 is ok? Keyboard is OK? If the keyboard and the dome is near,please try to power off and power on the PTZ! Preset the stop position and run speed! Link to comment Share on other sites More sharing options...
Alister Posted November 17, 2006 Author Share Posted November 17, 2006 Do you have any other PTZs on the Sprite? If it's all your PTZs on the unit which are moving slightly then the above poster is correct, simply calibrate the joystick.Unplug the keyboard, plug it back in whilst holding down the star key. Move the joystick to it's extremes (up, down, left, right, twist to zoom in and out) then press the star key again. Thank you all for the quick response and suggested remedies to the problem. Link to comment Share on other sites More sharing options...
