Optima Xm6
ajay 1
I have moved house and the house has a Optima XM6 alarm panel,when we set the alarm it works fine,but when we come back through the front door their is no delay and the alarm goes off before we can type in code any help would be appreciated ta Andrew.
Andrew, what about if you come in through the back door? it sound either as though it was set up for this or you have a sticking contact, either way I would recommend an engineer come and check it all over for your peace of mind.
The voices in my head are telling me to reply to that, but I won't :no:
Dave
It could be front door is your entry/exit route and the back dorr(if conected to the alarm) is programmed as a intruder zone.....you need an engineer
As for voices in your head???......you need more help than an engineer give matey :yes:
