Guest Douglass Posted November 20, 2006 Posted November 20, 2006 Hello! I have just bought a house fitted with an Optima 2 Plus alarm. This works ok but appears to be wired to one of the sockets circuit breakers in my comsumer unit. When this is switched out to permit electrical work elswhere the alarm sounds and the alarm panel goes dead. In effect no other work can be done on my sockets or ring main without the alarm sounding! Is there a cure for this? Thanks
Rich Posted November 20, 2006 Posted November 20, 2006 Hello! I have just bought a house fitted with an Optima 2 Plus alarm. This works ok but appears to be wired to one of the sockets circuit breakers in my comsumer unit. When this is switched out to permit electrical work elswhere the alarm sounds and the alarm panel goes dead. In effect no other work can be done on my sockets or ring main without the alarm sounding! Is there a cure for this?Thanks The cure would be to get the alarm system serviced, batteries changed and any faults rectified. The battery is either faulty or it is not being charged due to a fault with the alarm itself. Would probably be a good idea to get it looked at and set to how you want it.
james.wilson Posted November 20, 2006 Posted November 20, 2006 i agree with the above securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest Posted November 20, 2006 Posted November 20, 2006 Look on the bright side. At least nobody can steal your sockets.. Yeah, those brass ones are well expensive. All joking aside it sounds like a duff battery, but its best to check the charging cct as well.
mjw Posted November 20, 2006 Posted November 20, 2006 Hello! I have just bought a house fitted with an Optima 2 Plus alarm. This works ok but appears to be wired to one of the sockets circuit breakers in my comsumer unit. When this is switched out to permit electrical work elswhere the alarm sounds and the alarm panel goes dead. In effect no other work can be done on my sockets or ring main without the alarm sounding! Is there a cure for this?Thanks New Battery or a very large hammer
mjw Posted November 20, 2006 Posted November 20, 2006 Chances are a new battery wont fix it, charging circuit is probably u/s This is true..but always look on the brightside
