Texecom Bellbox Connections
Guest Grahams
Guest Grahams
I am having problems with connections of a Telexcom Odyssey 1E sounder to a Melcom ST6550 control panel
Texecom bellbox end are as follows
A(12v) Permenant posative supply
B(bell) Negative applied output to activate siren
C(tamp) Negative removed on tamper input
D(0V) Permenant Negative supply
S(strb) Negative applied output to activate strobe.
What are the corresponding Melcom control panel connections?
thanks
Grahams
thanks
Grahams
can such info be given out in the public forum :hmm:
Guest Grahams
I am new to this site.
Have I logged my request for information in the wrong place?
If yes My apologies.
Grahams
Why not? After all Texecom is a DIY product according to many in this Forum!
cheers
Dave
ps: I'm not going to be the one to do it though :no: , got modded yeterday by big bad James :D
Hello, Going by the installation manual I found online.
Panel---------------Bell
BELL + ----------- A(12v)
BELL - ----------- B(bell)
SAB1 RT --------- C(tamp)
SAB1 0V --------- D(0V)
STB - ------------ S(strb)
I think that is the right way to connect that panel to the texecom bell. Try it at your own risk.
djrock
To the Moderators, If you think the above diagram is giving too much away feel free to remove it.
