Grade 3
a1steve
TBH seen a few bugs with G3 and codes. Inculding Some pre V.5 sounding for an intruder 5 mins after switching off.
At one point we couldnt gain access with Engr pin even tho we used manager code to autherise access.
Tis when i got to hear about G3 having this Author Code Aka back door.
Bob
The Galaxy is full of bugs.
Try a Texecom Premier.
All praise the mighty Texecom.
Dave
ahh!! the "G3"! :no: ,we been getting customer phoning up over "beep" and "Alert,Enter Code" which started more customer callout/advice. :realmad: (i'm refering to galaxy G3.)
we even got customer with G2 ringing up saying system won't set with fob but giving aloud beep upon presentation of the fob,which we find that customer not acknowleging the fault/alarm prior to setting!! :no:
i thought you set with a code and unset with a fob... :hmm: this setting with a fob has caused quite a few probs for the galaxy.. :cry: whats the latest v software you guys have seen..???ive seen 5.06 tho was promised by honeywell that there were no bugs and it was still 5.01 :no: ....has the rem try been sorted!!!!!
this might sound very stupid, but i'm sure we are only using our 4 digit eng code on grade 3 installs?
As do we except we imagine its an old scanny panel ;)
that funny you mention "Rem Try" i had to check my national account customer system yesterday and came across that in the log of a G3 galaxy and it tripped the fault signal because rem try was followed by comm failed!! :huh:
just switch it off..option 47... if trys to dial out thru the night after any prog changes,something to do with this remote servcing thing,tho if you change an old gal 500 for a g3 and do the link up to download the old gal to the new gal on site,option 47 then becomes disabled.... :hmm:
Guest martin1
with the new regs wot is the nuber off pins that much be used on a grade 3 alarm for the enginer code and user code?
a min of 5
