Screw Fix Heavy Duty Contact 3 Wire
Guest davet
Yep that works well connect the 12vdc to those two, and everytime a burglar breaks in and closes the door your alarm will go off and not even you will be able stop it (youll need an endless supply of fuses though) :P
Yes now sorted thanks for your help and I bet I made you smile :yes:
Guest Alarm Guard
You certainly did! Forget doing the alarm. You could script write for Peter Kay. :P
