Optima G3 - Cannot Use Partset (program 2 Or 3)
Guest Wright
Hi
i've just finished installing an Optima G3 panel. I cannot set Program 3 to disable zone 4 (PIR on landing) when I follow the manual. When activating the panel to use Program 3 (night mode), the PIR on the landing triggers a full alarm condition.
Is this a known problem or is the manual incorrect?
Thanks
Adrian
Hi
Thanks
Adrian
Sorry to be so brutal but i would say its your programmong that is wrong :cry:
check your exit modes are correct for prog 2 and 3
I note from the engineer manual that the Exit Modes for Programs 2 and 3 are disabled (factory default). If my part set (night mode) is using Program 3, what should I set the Exit mode to be? Options are:
0 Disabled
1 Timed
2 Terminated Set
3 Final Door Set
4 Silent Set (use exit time)
thanks in advance
Adrian
0 Disabled
1 Timed
2 Terminated Set
3 Final Door Set
thanks in advance
Adrian
Er, to state the obvious, you use whatever is appropriate, but not 0. :ninja:
What do you want to do, e.g. how do you want/expect to operate the part-set?
(probably 1 or 4, but you never know.......)
i would go with that one...0 will do as it says on the label.....disable it
You proably would use 4
but then again????????? :blue:
I just to want to set Program 3 to be the Night set mode i.e All zones armed except Zone 4 (landing PIR).
I thought this would be achieved by choosing (quoting from manual) Used Zones then selecting/de-selecting the relevant zones to use for a Night Set program. Not sure I understand why the Exit mode setting of Silent Set (4) will cure my problem but will try it and report back.
