Veritas 8c Part Set
Guest jonsie19
Guest jonsie19
When I part set my Veritas 8c, it doesnt give me time to unset it like it does with full set. As soon as i walk past a sensor the internal sounder goes off. Is this normal or should it beep the same as full set?
Guest jonsie19
How can I do that? Also can I set it so I can go through two zones without it going off straight away?
Guest Alarm Guard
There are dozens of options in the programming of this panel. It needs to be set up in engineer mode.
