Changing The User Code In Aritech Cs350
Guest IoGuido
Guest IoGuido
Hi all
I've a CS350 installed and I need to change the arm/disarm code; I downloaded the user manual that says to press the down arrow to scroll the menu but this don't work even if i press 0 than the code; in this way the alarm become armed. How can I access to the menu to change the code? the arm/disarm code is the whole code the installer gave me so many years ago. I tryed also the engineer code (DELETED BY MODERATOR) but seems to be incorrect.
Thank you for your help, Guido.
Hi all
I've a CS350 installed and I need to change the arm/disarm code; I downloaded the user manual that says to press the down arrow to scroll the menu but this don't work even if i press 0 than the code; in this way the alarm become armed. How can I access to the menu to change the code? the arm/disarm code is the whole code the installer gave me so many years ago. I tryed also the engineer code but seems to be incorrect.
You need to use the managers code.....code in panel says arm menu Push the Down arrow untill panel says change codes....
N.B 0 ACTS AS AN ESCAPE KEY..YOU WILL NOT BE ABLE TO HAVE A ZERO IN THE CODE NUMBER
good luck ;)
Guest IoGuido
good luck ;)
What's and where I can find the managers code?
Thank you so much!
Thank you so much!
well if you do not have the managers code you can set users up in engineering menu,but if you don't have engineers code you need an engineer to default system and reprogram B)
if you pay the air fares and acommodation, i will gladly come and fix it for you :whistle:
Get in the queue i am at the front!!!!! :gimme:
thats you out then CJT
As i said i am first..i am closer to italy than you are anyway 2674 miles you are a tad further away at 2765
