How To Change Pin Of Remote User On Galaxy
Guest ericw
Hi all,
Strugggling for some time now to get my remote connection work... :(
Default password does not seem to work.
Actually, level 8 user seems not to be displayed when looking at the user codes as engineer or manager.
Did not find too much info in the manual either. ( Except some mention of the keypad E, if that means it can only be done from a keypad with address E ? )
I do get an ethernet connnection, when looking with netstat, there is a connection on the right ports.
All communication parm are set to direct access, any time. I get a password denied message, so the only thing I think is that my remote user PIN is not the default anymore, but I cannot display this user...
So here is the 5 cent question for you galaxy experts:
- how can I see the remote user and change the pin on my galaxy 18 ?
Thanks for any help. :gimme:
Eric
I did, actually I use it more as a home automation system then an alarm system ( i do not even have a bell connected to it)....all sensors activate rio outputs, that are connected to a ocelot/secu16 module which send X10 signals on the electricity network to activate the X10 modules that control my lighting....
I now want to hook it up on my network for logging...but I ran into the problem described above.
