Hi Ya All
Guest TeknoTel
Guest TeknoTel
Hi everyone,
I hope someone can help, I've just moved to Braintree and the house has an alarm with 'countess' written on the control panel but I've no user manuals and cannot find any info on this alarm. The name and telephone number on the alarm sounder reads TMW (0376) 24964 but they seem to have ceased trading.
The previous owners have given my the code but I need a manual before I start changing codes etc.
Can anyone help?
Link to comment
https://www.thesecurityinstaller.co.uk/community/topic/13982-hi-ya-all/
Share on other sites
Guest TeknoTel
Thanks for the User Manual, Much appreciated.
When Peter states it's a 'potential time bomb' what's he referring too?
I've noticed that one of room pir's doesn't light - does this mean it's turned off or faulty? When I set the alarm it emits a continuous tone, so I'm assuming every thing is ok with the system at present.
Thanks for you help,
Terry.
Guest TeknoTel
It might, if the current code is user code 1 - only one way to find out :whistle:
Under walk test it then states
'The system devices may now be operated, the display will show the zones operated and a high level sounder will follow the status of the zone(s) under test'.
What does this mean??
How do I preform a walk test??
Any help will be appriciated.
Tekno, no offence but i think you need someone in for this, by all means get them in fix it and ask them to train you on user functions like your bell and walk tests, how oftne they should be done, show where the coverage is etc etc. If you dont want a service contract then fine but at least get trained on how to use your system as a minimum. I assume someone will do this for a fee
