Satellitte Installation Gurus?
Guest THOMSONSECURITY
28.2 astra 2a sillyness :mellow:
I've Got a Triax Zone 2 dish with a Thomson single LNB 0.6 whatsits
& the signal strenth shows 2/3 (Same wiv the quality) (Pace 2200 shaddap I like it)
Just changed the LNB to a Cambridge Quad 0.6 whatsits too, (Sky + Comming Soon) & the signal has dropped to 50% (Both readings) WTF is that all about ?
umm I went to The Zone 2 version due to lack of signal & chronic pixelation during inclement precipitation....... But this New LNB seems to of set me back nearly to where I first started :angry:
Anyone got any suggestions
John
  • 1 month later...
Guest macey
have you realigned the dish because sometimes it is required but as long as you are still getting a picture and the signal is at least 50% of the bar i wouldnt worry as some of the stb have manufactured signals to make you think it is a better system
Panic not, I had to re align it...... The thing nosedived, wiv the new weighty LNB,
This Triax dish seems a bit cheepo'
Still it works....... Any more grief wiv it tho & its heading for the skip :D
