Guest iant244 Posted December 13, 2006 Posted December 13, 2006 Hi guys,just wonderin if u could help with a problem,moved into a property and it has a Optima Compact fitted but the person who was in it before forgot the code so had to pull the fuse and take the battery out,is it possible to reset the whole thing so i'll be able to use it again thanks Ian
james.wilson Posted December 13, 2006 Posted December 13, 2006 yep anything is possible. I would recommend you find yourself a good local company, a few cover each area so you shouldnt have a problem. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
ARJ Posted December 13, 2006 Posted December 13, 2006 Hi guys,just wonderin if u could help with a problem,moved into a property and it has a Optima Compact fitted but the person who was in it before forgot the code so had to pull the fuse and take the battery out,is it possible to reset the whole thing so i'll be able to use it again thanks Ian Yes, it is possible to reset the codes,but this is something a local Alarm engineer will be able to do. Sorry, but we can not give out defaulting information on a public website. Post your location and we may be able to recommend somebody near you. ARJ A nearly retired previous installer !
Guest iant244 Posted December 13, 2006 Posted December 13, 2006 yep anything is possible. I would recommend you find yourself a good local company, a few cover each area so you shouldnt have a problem. Ive downloaded a manual for the compact rf cos thats the only one i can find,would i be right in thinking they both use the same engineers code Yes, it is possible to reset the codes,but this is something a local Alarm engineer will be able to do.Sorry, but we can not give out defaulting information on a public website. Post your location and we may be able to recommend somebody near you. ARJ Im near Warrington in Cheshire
ARJ Posted December 13, 2006 Posted December 13, 2006 Im near Warrington in Cheshire There are a couple of Alarm companies registered on this site who are based in Manchester and cover the Mersyside area: JB-EYE Fire & Security and Nova Security, - I'd suggest you give one of them a call ARJ A nearly retired previous installer !
ARJ Posted December 13, 2006 Posted December 13, 2006 or even... Advanced Webb Security Systems Ltd - 4 Lovely Lane Warrington WAS 1AF Phone: 01925 654174 Web: www.advancedwebbsecuritysystems.co.uk who are actually in Warrington A nearly retired previous installer !
