Galaxy 16+ And Odyssey Bell Box
Guest hylandz
Guest hylandz
hi
need some wiring help please
tihs is how i have wired it but panel says the bell is still in tamper
Bell Galaxy
+Ve Supply + Hold
- Ve Bell Bell
- Ve Tamper T
0V - Hold
- Ve Strobe Strobe
Theres also a LF terminal next to the T terminal on the board
Im use to installing fire alarms so am i little stuck
Thanks i advance
  hylandz said:
hi
Bell Galaxy
+Ve Supply + Hold
- Ve Bell Bell
- Ve Tamper T
0V - Hold
- Ve Strobe Strobe
Thanks i advance
Silly question..lid is on bell correctley??..if not On your sounder have you got a terminal marked tamp feed as you will have to feed a 0v down it.... :ninja:
Guest hylandz
Yeah lid is on properly.
No, just the connections listed, could i not put a link from the 0V to the T on the bell? what that clear it?
It will but the tamper wont work are you sure there is'nt a link to switch between + return or -??? :unsure:
you could have a faulty siren...best way to check go up to bell with your meter and hold tamp in and meter to see if you are getting a - return
What are the LED`s doing on the oddity, one flashing only or both alternating?
cheers
Guest hylandz
cheers
the left one is flashing slowly
Guest hylandz
thanks
i'll get up there and have a look in the morning
