Guest jasonb007 Posted December 15, 2006 Posted December 15, 2006 I have moved into a house with an ADE Optima Compact Alarm control panel. The previous occupiers do not know the code. I have tried various options like restting using the setup info from an Optima Compact G3 manual but nothing seems to work. My alarm box has 6 zones and SQUARE buttons. Does anyone know how I can reset this box. I think the engineer code of ---- still works but following the info in the G3 manual to change the code doesn't. When I press PROG, ALL the LEDS come on, then pressing ---- the Day (green LED), Attack & Power LEDS (RED) light up. However, when I follow the info to change the code in the G3 manual I entered PROG ---- 81 xxxx (where xxxx is the code I want) but after entering the third digit in the xxxx code, the alarm beeps a couple of time. Any ideas. I have attached a (rubbish) picture of the control panel. Engineer code edited out by moderator
Guest CHRISATBSS Posted December 15, 2006 Posted December 15, 2006 THE PANEL YOU HAVE IS NOT A OPTIMA (G3) JUST A OPTIMA COMPACT G3 IS THE NEWER VERSION . IF YOU HAVE THE ENGINEER CODE THEN PUT THIS IN THEN PRESS BUTTON 8 THEN NEW CODE A SERIES OF BEEPS WILL BE HEARD TO CONFIRM ACCEPTENCE PRESS RESET UNTILL ALL LIGHTS ARE OUT EXCEPT DAY AND POWER LIGHT.JUST READ YOUR PROB AGAIN AND REALISED YOU ARE PUTTING IN A 1 IN AFTER THE 8 YOU DONT NEED THIS BY PUTTING THIS IN YOU ARE MAKING YOUR CODE START WITH A 1 AND REMOVIG THE LAST DIGIT FROM THE CODE YOU WANTED EG 2345 WILL BECOME 1234 IF THAT MAKES SENCE IN SHORT PROG ENGINER CODE 8 NEW CODE BEEPS RESET RESET NOW TRY THE NEW CODE CHRIS FROM AXIS FIRE & SECURITY
Anusoflannigan Posted December 15, 2006 Posted December 15, 2006 Hi you are so near...Press prog ----, 8, new code(forget the 1) system beeps after the 4th digit to confirm new code. ( you always entered 1 as your 1st digit) and again. Come on guys. Stick to the rules
Guest jasonb007 Posted December 18, 2006 Posted December 18, 2006 Hey Guys, thanks for the info. I have managed to enter a new code and am SO grateful for your prompt replies and assistance - now all I need is a User Guide so I know how to operate the system !! I guess a search on Google may uncover one somewhere, although I still don't know the name of the alarm (apart from it's not a G3) Thanks again.
dommer Posted December 18, 2006 Posted December 18, 2006 Hey Guys, thanks for the info. I have managed to enter a new code and am SO grateful for your prompt replies and assistance - now all I need is a User Guide so I know how to operate the system !! I guess a search on Google may uncover one somewhere, although I still don't know the name of the alarm (apart from it's not a G3)Thanks again. Try this http://www.tlc-direct.co.uk/Technical/Data...NTA6_8_User.pdf
paulstas Posted February 20, 2007 Posted February 20, 2007 Try this http://www.tlc-direct.co.uk/Technical/Data...NTA6_8_User.pdf I too Have this alarm and after a fuse blew recently the alarm went haywire..I have managed to get my user code code back after following the above instructions ..However since then my entry and exit times have gone all to pot.. when setting alarm to leave timer seems to go on forever..Also when coming downstairs and passing the pir the timer starts but as soon as I walk into the living room (zone 2) the alarm sounds!!..Anyone got the full user manual for this alarm or instructions on how to sort out my problem..Much obliged Paul
Fatboy Posted February 20, 2007 Posted February 20, 2007 I have moved into a house with an ADE Optima Compact Alarm control panel. The previous occupiers do not know the code. And they had really a really bad taste in wall paper Big Jig. Trade Member Quality Manager Direct Security Systems (Midlands) Limited NSI Gold. Good engineers always ask questions!!
