BASS Posted December 15, 2006 Posted December 15, 2006 Anyone know where I can get hold of a INSTALLATION MANUAL for the BT REVELATION phone system need one desprate Thanks Guys
F C E Posted December 15, 2006 Posted December 15, 2006 Anyone know where I can get hold of a INSTALLATION MANUAL for the BT REVELATION phone system need one desprate Thanks Guys Try This http://web.ukonline.co.uk/freshwater/revalat1.htm All comments in this post are my own views and do not necessarily reflect the views of my employer
BASS Posted December 15, 2006 Author Posted December 15, 2006 Thanks Mate but I have got this information it's just trying to understand how to program the with this lol Thanks M8 if you can make head or tail would be great Thanks M8
camerabloke Posted December 15, 2006 Posted December 15, 2006 http://web.ukonline.co.uk/freshwater/useguide/revelat1.htm nope same as above http://www.htcnetworks.co.uk/BT%20Pathway%...h%20Telecom.htm try this Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Simon_B Posted December 16, 2006 Posted December 16, 2006 Bob Freshwaters site info is probably the only info you will find online about the Revelation in terms of programming. The other link is more dangerous than helpful as it is for a different system with completely different programming access and codes - you could actually screw something up trying to enter Pathway codes for a Revelation. In fact many Pathway owners have downloaded that manual and screwed up their system through not understanding what they were doing as it is. BT Revelation won't be found on PDF - too old but I have a big old bound paper copy and worked on it for years if members need help with anything. Simon ToneTel Telecom www.tonetel.co.uk
84peace Posted January 11, 2007 Posted January 11, 2007 can u make a copy of that manual for me??PLEASE. i would be very thankfull!it's urgent for me Bob Freshwaters site info is probably the only info you will find online about the Revelation in terms of programming.The other link is more dangerous than helpful as it is for a different system with completely different programming access and codes - you could actually screw something up trying to enter Pathway codes for a Revelation. In fact many Pathway owners have downloaded that manual and screwed up their system through not understanding what they were doing as it is. BT Revelation won't be found on PDF - too old but I have a big old bound paper copy and worked on it for years if members need help with anything. Simon
Razzler Posted July 14, 2007 Posted July 14, 2007 Bob Freshwaters site info is probably the only info you will find online about the Revelation in terms of programming.The other link is more dangerous than helpful as it is for a different system with completely different programming access and codes - you could actually screw something up trying to enter Pathway codes for a Revelation. In fact many Pathway owners have downloaded that manual and screwed up their system through not understanding what they were doing as it is. BT Revelation won't be found on PDF - too old but I have a big old bound paper copy and worked on it for years if members need help with anything. Simon Simon...Hope that you are still using the forum or maybe if anyone else knows?? I have just installed a Revelation in my B&B...I have a system phone in the office, five extensions using BT Converse 1100's one in each of the bedrooms and I intend to use a couple of PBX friendly DECT phones for private use. Now...Am I just a bit thick or... I have managed to wire the PBX OK, but found that I needed to use the O/WT bell wire in position C (3) for the Converse phones to ring (does this sound right?? thought you only needed a pair!). I have checked out a couple of the features such as 'wake up call' etc. and all works on all extensions OK. The thing that I can't work out is how to stop the bedrooms from making external calls and also how to stop them receiving external calls (unless transferred from the system phone in the office). Also...If I have the dining room extension taking unanswered calls from the office (in other words, if I am cooking breakfast rather than sitting in the office with my feet up!!), can I then forward that call from a none system phone to another extension? Hope I've not confused too much??...Steve
Simon_B Posted July 16, 2007 Posted July 16, 2007 Simon...Hope that you are still using the forum or maybe if anyone else knows??I have just installed a Revelation in my B&B...I have a system phone in the office, five extensions using BT Converse 1100's one in each of the bedrooms and I intend to use a couple of PBX friendly DECT phones for private use. Now...Am I just a bit thick or... I have managed to wire the PBX OK, but found that I needed to use the O/WT bell wire in position C (3) for the Converse phones to ring (does this sound right?? thought you only needed a pair!). I have checked out a couple of the features such as 'wake up call' etc. and all works on all extensions OK. The thing that I can't work out is how to stop the bedrooms from making external calls and also how to stop them receiving external calls (unless transferred from the system phone in the office). Also...If I have the dining room extension taking unanswered calls from the office (in other words, if I am cooking breakfast rather than sitting in the office with my feet up!!), can I then forward that call from a none system phone to another extension? Hope I've not confused too much??...Steve TBH Steve - I think you need an engineer round to help you. None of this is technically difficult but if you don't have the engineering manuals or any experience on the switch, you will struggle. Get rid of the bell wire for the PBX extensions - where is that being fed from anyway ? Its a PBX, use PBX Master sockets with capacitors inside or use telephones that have internal capicitors (normally Interquartz etc) or alternatively any mains powered phone. Basic UK telecoms stuff - bell wire is of course used in domestic situations to feed extension sockets (secondaries). Its a pair for POTS (standard phones) or 2-pairs for system featurephones. Stopping Extensions making external calls > Admin Programming (Class of Service) assign required extensions to class 4. Stopping Extensions ringing for external calls > Admin Programming (Incoming Ringing) take required extensions out of day/night service ringing group using the Busy Lamp Field (BLF). Reference the dining room, can you forward calls to another extension - do you mean call transfer to another extension? If so tehn yes dependant on model of phone and that it has a R (or Recall/Flash key) - UK spec - press R, await internal dialtone then dial required extension, hang-up to transfer call. Regards Simon ToneTel Telecom www.tonetel.co.uk
Razzler Posted July 21, 2007 Posted July 21, 2007 Thanks for that Simon...I had some BT masters to hand, so fitted them, lost the O/WT wire and all extentions now work well (and quieter) on 2 wires. Regards the transfer question...If I am working in the kitchen and transferred any extenal inbound calls from the system phone in the office to the phone in the kitchen, can I then transfer those calls received in the kitchen to a room phone or even a dect phone situated in the private side of the house (also an extension on the PBX). Does the phone in the kitchen need to be a system phone?...Thanks again for your time...Steve
Simon_B Posted July 21, 2007 Posted July 21, 2007 Yes its a phone system so you can transfer calls around as you need to. You can use nearly any phone you want as long as it has Time Break Recall - R or Recall key. Simon ToneTel Telecom www.tonetel.co.uk
