Bt Revelation
BASS
Thanks Simon...
I have just spent an hour or so trying to get my head around the programming side.
I think that I am missing something very simple!!...Please bear with me.
You kindly gave me the information on how to stop certain extentions ringing out and receiving inbound calls (but can still receive internal calls).
I have dialled in the default code 70 followed by 111 and have 'Dial Admin Code' on the display.
What do I tap in next (step by step)?
Sorry to be a pain, but I need to get this done in the next couple of day's (opening my B&B).
Many thanks again...Steve
Thanks Simon...
There are 2 Levels of programming (Engineer and Admin), and you have just revealed your admin password to all in a public viewable forum, which is probably not a good idea.
Dial Admin Code means - dial the code associated with the programming step you want to change, refer to your BT Revelation Owners manual or "call a man in".
Its going to take me too long to tell you step by step how to do every single one of these changes "step by step", basically if you have no idea of the programming, read your manual (if you have one) or get someone in if it is urgent.
I don't mind pointing you in the right direction but thats a bit of difference from step by step which is going to take me some time to type out to someone with no programming knoweldge at all - and I am not going to do all that in a public forum anyway.
All extension programing is controlled by the BLF lamps (on or off to set the extension).
Simon
ToneTel Telecom
www.tonetel.co.uk
Hi again Simon
Sorry...I did not mean you to show me everything to do with the programming...Just an instruction line (>>>) on setting the extensions not to have access to or receive calls from an outside line.
I.E. Dial Admin Code>*****>*****> etc.
Oh...the codes which I gave out on the forum are the factory default codes and not my own.
Thanks again...Steve
  • 7 years later...
Hi all
Can anyone help. I have a Revelation 2+6 that has been working without problems for about 10 years. For some reason the system appears to have reset itself. I can obtain an outside line by pressing the line key on the master phone, but when I dial 9, all I get is the engaged tone. I have checked that all extensions are enabled and that the exchange line is presented to extensions, I have also checked config code 50 all lines both incoming and outgoing, PABX access set to 9 on lines 1 and 2. But I just cannot get an outside line by pressing 9.
Please help
Thanks
