Aj600 To Texecom 3e
Guest Jeff
I have an old AJ600 that i am trying to wire to a new Texecom 3E bell box i have the following
AJ600
Black - to bell
Red + to bell
Green 0 to SCB
White RT(return) to SCB
Blue + to STR
Yellow - to STR
The bell box only has the following
A (12V)
B (Bell)
C (Tamp)
D (0v)
S (STRB)
Can anyone explain which wire needs to go to the bell box connections? Currently have 6 Bell only has 5!
Thanks
Easy,
A to red
B to black
C to white
D to green
S to yellow
red and blue do the same job so you can either put both wires in th eA terminal or insulate one.
Regards and Merry Christmas
Bellman
AJ600
Black - to bell
Red + to bell
Green 0 to SCB
Blue + to STR
Yellow - to STR
A (12V)
B (Bell)
C (Tamp)
D (0v)
S (STRB)
Thanks
Your new bellbox probably shares the 12v+ with bell and strobe, so you don't need the blue + to strobe from the panel.
So it should be:-
Black to B (0v-)
Red to A (12v+)
White from C to RT Return (0v-)
Green to D (0v-)
Yellow to S (0v-)
