Service Engineer Posted December 27, 2006 Posted December 27, 2006 It sounds as though the battery was too discharged, and caused an error on powering up. This is a common fault with many older alarm systems. Replace the battery, leave to charge a few hours... Discon the battery and mains. Power up the panel battery first, and enter your code to silence it if required. Replace panel lid, re-instate the mains, reset alarm system as per user reset instructions. If the above does not cure the problem, or if you are uneasy following this procedure, then please call a competant alarm engineer to do this for you. ........................................................ Dave Partridge (Romec Service Engineer)
