Guest djlay Posted December 29, 2006 Posted December 29, 2006 I have a DA Systems Abacus panel. I need to find a way to access the Engineer programming menu. Ive figured out that 1234 is a default code, suspect user code. It gives me a menu as follows, 1=Code 2=Chime 3=Time 4=Engnr. I select option 4 and it asks for another code. Does anyone know where I might get an engineer manual for this? Thanks in advance, D
mjw Posted December 29, 2006 Posted December 29, 2006 I have a DA Systems Abacus panel. I need to find a way to access the Engineer programming menu.Ive figured out that 1234 is a default code, suspect user code. It gives me a menu as follows, 1=Code 2=Chime 3=Time 4=Engnr. I select option 4 and it asks for another code. Does anyone know where I might get an engineer manual for this? Thanks in advance, D Cannot give info out in public area,to get a manual
