Guest darkmagi Posted December 29, 2006 Posted December 29, 2006 I had my Alarm installed by alarm engineer & it has been fine for the last year but i just noticed a strange fault with it, When the alarm is part/full set if i come in through my front door only the interior alarm sounds, even if i trigger a sensor while the interior alarm is going off after entering through the front door the exterior alarm does not sound, If i set the alram part/full & trigger a sensor in one of my rooms the interior & exterior alarm sounds, I have checked the manual but i cannot find a way to set the alarm so the exterior alarm sounds if i do not enter the code into my pad after coming through my front door, As this is the entry/exit area for my alarm its seems strange that someone could kick my front door in & strole into my house without the exterior alarm sounding. I just wanted to know if this is normal with this make of alarm or if there is a code i can input into the alarm to turm the exterior bell on if the front door switch is triggered. ..........Tom.
Guest Posted December 29, 2006 Posted December 29, 2006 dual ply.............. wait just a wee bit longer
Guest darkmagi Posted December 29, 2006 Posted December 29, 2006 So thats what duel ply means, Thanks for that, I have tried it & it does work if i leave the interior bell sounding for 30 secs, I just wished that it would tell you this in the manual but i suppose thats to stop prats like myself from mucking about with things they know nothing about....... Thanks again for the promp responce
