Guest dflorence Posted December 30, 2006 Posted December 30, 2006 Hi, I hope some of you kind people may be able to help me. I have just moved house and have inherited an alarm fitted with a JSB regent 8 zone panel. The previous owner has left me with his user code no. but that is all. I have found the engineer manual for the system on the net but its far too complicated, all I want to do is change the master user code and perhaps add another code for our neighbours when we are away. The engineer manual tells me that to change the user code I should refer to the Regent user manual, which I do not have. If anyone could tell me the procedure to change the user code I would be grateful. Many thanks.
Guest dflorence Posted December 30, 2006 Posted December 30, 2006 RegentUser.pdf Whay a brilliantly helpful site. Thank you!!
newguy Posted February 2, 2009 Posted February 2, 2009 I need a user guide for the Regent 8 zone panel. Can anyone supply me with one as the previous link no longer works? Many thanks There's no substitute for experience .......... so all opinions welcome!
newguy Posted February 3, 2009 Posted February 3, 2009 Hope this helps. Just the job! Thanks again RJBsec. There's no substitute for experience .......... so all opinions welcome!
