Guest sandersfield Posted February 19, 2004 Posted February 19, 2004 Hi, I've moved into a new house and the existing SL Compact Alarm has been power down for about a year (fuse from fised spur removed). When replugging the fuse, the alarm immediately goes off and I don't have the operator or engineer code from the previous owner. Is there a way of clearing the NVM, or resetting back to Factory Default settings ? Any help would be appreciated. Also I'm sure a manual would help at some point in the future if anyone has it in electonic format ? Kind Regards, Paul Sandersfield
Guest simonrob Posted February 19, 2004 Posted February 19, 2004 I would suggest that you get a local alarm company in to service the alarm if it has not been powered up for a year. If you let us know what part of the country you are in, somebody locally may be able to help.
Guest alarm man Posted February 19, 2004 Posted February 19, 2004 have you tryed the ade web site http://www.ade.co.uk
