Replacement Door Contacts
Guest Guest_Allan
Guest Guest_Allan
Is it possible to change door mounted allarm contacts in a wooden door for surface mounted cntacts on a replacement UPVC Door
You can still mount flush contacts in UPVC doors, just ask the door fitter to run rhe cable into the frame and drill a 20mm hole where its to be mounted.
Service Engineer
My opinions may not reflect those of my employer, managers, colleagues, customers, friends, family or pet rabbit.
Don't forget the steel reinforcing in some frames and doors!
Tends to blunt your 20mm spade bits!
Steve Kendall
Plymstock Security Systems
