Cct715
thomas
  • 2 weeks later...
What VCR are you using?
You will probably need a BNC plug for the DVR and a scart socket for your VCR, if your VCR has a phono video input then a BNC to BNC lead with a BNC to Phono adapter should work, or a scart plugged cable with a phono to BNC adapter.
The signals will be the same you will just have to select the input on your VCR.
