Replacement Door Contacts
Guest Guest_Allan
Guest Guest_Allan
Having lokked in the control panel to see which wires go to the flush contact on the door I now have a tamper light indication on the control panel - The user manual says contact the installer (who are now no longer in business) How do I reset / remove the tamper indication from my control panel (Scantronic 9448) - Thanks in anticipation
Allan
Try entering your user number and pressing enter.
If not try 99 and then enter.
If this doesn't work call an engineer! What model of 9448 do you have?
Steve Kendall
Plymstock Security Systems
Guest Guest_Allan
Steve the control panel just has 9448 on the front and is 5 years old according to the Neighbours
Have tried the user number and enter but on the walkthrough test the tamper light relights and the intrnal sounder is intrmitant
cheers
Allan
If tamper only comes on during walk test, it sounds like you've got zone and tamper pairs mixed up and instead of indicating an active zone its coming up tamper.
Glenn
Guest Guest_Allan
I Have been advised that I need to put in the engineers code as this is not available (they have ceased trading) the other alterntive is to reset and reprogramme the system to factory setting
Any help would be appreciaated
Allan
Open the panel and put two links across the offending zone. Close the panel and try and set it.
If the system works okay then it is the wiring to the door that is wrong.
REMEMBER THERE IS MAINS ELECTRICITY IN THE PANEL and it can KIll
Colin.
