ADEVA Cam 8 camera system
Guest Adrian
Guest Adrian
Has anyone used Adeva's Cam 8 camera system? (yes I know Adeva is no more!)
I need to do a quote for a bungalow that wants 3 cameras. Records only when they are out or at night using a standard video recorder. The system above has built in movement sensors (In the cameras that is) That trigger the Cam 8 to record.
I have used this system once in the past but had a number of problems with it after a number of power cuts. (I think it got spiked)
Has any one else used this system in the past? If so what are your thoughts.
Or can you recomend a simmilar system that you use with sucess.( a link as to where I can get it would be helpfull as well)
Adrian
Guest Adrian
:( I guess by the large response that means no on has even heard of one of these.
Ow well
Adrian
Guest Adrian
Thanks for that
Adrian
