Delay In Alarm Activation
roadrunner1
I have a Pyronixs Sterling 10 alarm system that I've installed over 5 years ago. Up until a couple of months ago everything was fine but when you now activate the alarm system either through an activation by a panic alarm or PIR there is a delay before the bell sounds which can be between 10-30 minutes.
Ive checked the Bell box itself and its fine so beleive it's the main control unit.
Before I go and replace the main control unit I wanted to know if anyone may know what the fault may be.
Many thanks
Has anyone programmed a bell delay into the system parameters?
Has the panel been subjected to lightning or electrical interference?
I don't use the Sterling 10 {spit} so cannot offer any further advice I'm afraid.
To all the above the answer is no.
Thanks anyway
TEXECOM BRIGADE HERE :drive1: lol
If it's a DIY install I would recommend a Texecom Veritas Excel
m8
I am 1 of the few in the Gardtec brigade and i would fit a 480 panel. If you cannot get hold of one hen the CP8 panel will do the job.
Many thanks
Have you ried to default the panel and reprogramming it??????? :rolleyes:
gardtec are the best allround, i use em for every thing[bells,panels, detectors] no need to use any other brand as they make everything, and well.
me too Aaron,
i like to follow the analagy 'why fix what ain't broke' and Gardtec never is broke so i don't have to fix it - have yiu read the 'GAL' area :whistle:
regs
alan
