Guest rjbsec Posted February 12, 2007 Posted February 12, 2007 Not like the hard wired node has no fuses protection or outputs . It's a wireless node!
Guest Posted February 12, 2007 Posted February 12, 2007 It's a wireless node! Haven't you used wireless fuses before then?
petercts Posted February 21, 2007 Posted February 21, 2007 Hi folksAs the title says, I normally use Menvier TS590 and TS690 panels in domestic applications but am now looking at the M550 and M660 panels. What's the general opinion on these ? Are they well regarded ? Also, I tend to use SD2 fixed-line speech-diallers - they're great - but what GSM diallers are known to be good ? Frank
petercts Posted February 21, 2007 Posted February 21, 2007 m 750 panel is the best of all the m panels i am a sub contractor and have fitted over 50 of these m800 ok but onboard digi problems m1000 ok have only fiitted 4 with a max of 11 nodes you need a laptop with the downloader software ps i am still new to fitting alarms its only been 29 years remember relays &end of line battery
Monty Posted February 21, 2007 Posted February 21, 2007 It's a wireless node! yes but could still have a protective fuse to stop fault in node taking down network was what i had in mind www.AllanMoncrieffAlarms.com
Monty Posted February 21, 2007 Posted February 21, 2007 m 750 panel is the best of all the m panels i am a sub contractor and have fitted over 50 of thesem800 ok but onboard digi problems m1000 ok have only fiitted 4 with a max of 11 nodes you need a laptop with the downloader software ps i am still new to fitting alarms its only been 29 years remember relays &end of line battery We are looking at upgrading a 900+ as have only 2 spair zones so are looking at the M1000 would appear that the xnodes work ok with new panel but do you know if the lec 2>6 zone will work as the job has 2 - 2 zone lecs fitted. www.AllanMoncrieffAlarms.com
Guest Posted February 22, 2007 Posted February 22, 2007 We are looking at upgrading a 900+ as have only 2 spair zones so are looking at the M1000 would appear that the xnodes work ok with new panel but do you know if the lec 2>6 zone will work as the job has 2 - 2 zone lecs fitted. Depends how the lecs are wired, if in daisy chain fine if starred forget it.
petercts Posted February 22, 2007 Posted February 22, 2007 We are looking at upgrading a 900+ as have only 2 spair zones so are looking at the M1000 would appear that the xnodes work ok with new panel but do you know if the lec 2>6 zone will work as the job has 2 - 2 zone lecs fitted.
petercts Posted February 22, 2007 Posted February 22, 2007 m 1000 will work with lec or lec 6 but must go on network 1
Guest Posted February 22, 2007 Posted February 22, 2007 m 1000 will work with lec or lec 6 but must go on network 1 Try putting a LEC last after a RKP, or if thats how it was wired and you cannot recable.
