Laptop Battery
Adi
Has anyone any tips for replacing a laptop battery, ive undone most screws and no joy. Would you normally have to remove detach screen.
Its an advent 7001.
If not ill have to take it to IT doctors.
Not sure if ive asked this question before!
cheers
Its an advent 7001.
cheers
I've replaced mine recently i have an amilo fujitsu siemens it was 4 screws and the square cover just slid off!!
Its an advent 7001.
cheers
BE CAREFUL! :realmad:
Most laptops don't need any screws undoing to remove the battery.
Have a look here: http://www.uktsupport.co.uk/advent/laptop/7001.htm
If it looks like that you just slide the latch and pull the battery out
Sorry im a weirdo, i meant the cmos battery.
Take it to the PC Doctor!
If you really want to do it yourself you'll need a manual to see how to open it up without damaging anything, and the battery is probably under the keyboard.
Why do you think that's the problem anyway?
Because every time i start i have to go into settings reset the date before it will start and have been told its that battery.
You agree?
You will need the service manual, as some have to lift the keyboard up and some require the bottom taking off.
Watchdog Security (Manchester)
Ill going to send it to the laptop doc coz i might end up with a bag of bits.
Get a pro in to service it as we all say. :yes:
another graduate passes out of the NSI colledge with honours :rolleyes:
just makes me all teary eyed and weepy when that happen's ;)
regs
alan
