Guest BrianT Posted May 17, 2003 Share Posted May 17, 2003 Hi there, I'm looking for help on installing an Aritech AS522 bellbox kit with my existing CS350 control panel. Does anybody know where inputs 1,2,3,4,5,6 (AS522) should be going into the CS350 control panel. Any help would be appreciated. Brian Link to comment Share on other sites More sharing options...
Service Engineer Posted May 17, 2003 Share Posted May 17, 2003 Below is the correct wiring for the AS500 Series external bellbox Hope this helps. 1 = beacon (strobe) hold off 2 = siren switched negative 3 = + 12 Volts 4 = 0 Volts 5 = Tamper 6 = Tamper ........................................................ Dave Partridge (Romec Service Engineer) Link to comment Share on other sites More sharing options...
