Guest johnahealey Posted February 27, 2004 Posted February 27, 2004 Well maybe I'm getting the wrong end of the stick entirely - or maybe I'm just confused (more likely) With the model I have (Optima XM6) I can program it to get access through my lounge and kitchen (using a timers) to the panel, however I cannot change the entry/exit point without some re-wiring. Correct....?
FASTCAR Posted February 27, 2004 Posted February 27, 2004 Sorry , too much info ,these were just examples to explain the zone functions of your particular panel. zone 1 : front door (timed) zone 2 : lounge / diner (intermeadiate) zone 3 : back door (immeadiate)
Guest Peter James Posted February 27, 2004 Posted February 27, 2004 you could put the front and back door on the same circuit (zone 1) but zone 2 is the only zone you may walk through to get to the panel without causing an alarm. Pete
Guest lev Posted March 13, 2004 Posted March 13, 2004 There are no part sets on the XM6 only a omit function. To get into engineers mode you have to press PROG then user code followed by PROG engineers code. Zone 1 is Entry/Exit Zone 2 is a walkthrough(time inhibited) Zone 3 - 6 are immediate The only programming available is change Entry time/Exit time and Bell time.
