Couple More Veritas 8 Questions
andytw
Hi,
1. Page 22 of the manual says "It is also possible to program which part set(s) will cause the zone type to change"
I cannot see how this can be done. Have I missed it somewhere in the manual.
2. It appears to be possible to use ALL codes 21, 22 and 23 to set ALL zones to change.
e.g. Zones 1-8 can be set in 21 AND 22 AND 23 all at the same time.
Presumably there is a requirement to set a zone in either 21 or 22 or 23 an keep your eye on where you have set it.
Again, am I missing something.
Thanks,
andytw
