sparky83 Posted January 30, 2007 Posted January 30, 2007 I havent got much experience dealing with suites but what you can have a play at is setting up one code that has all the areas assigned to it. It should enable you to put your code in press 'AREA' then if you press 1 for area A, 2 for area B etc and it should enable you to turn areas on and off. Have a go .... Trade Member
martlewis Posted January 30, 2007 Author Posted January 30, 2007 Think I'll just add a keypad in the workshop and keep it completely local. The main thing to resolve now is just the fact that for some reason chime doesn't work if the system is part set in any way. Seems a bit daft really but I can't find a way round this?
